RE: E-FLIGHT BLADE CP
Raising the throttle trim doesn't lower headspeed, it increases it. Increasing your blade pitch by modifying the pitch control links, however, will allow you to hover at a lower headspeed.
Actually, I was just thinking, does changing the trim modify the pitch curve of a BCP? If this is the case, then maybe you're right. Regardless, I just lengthened the PCLs by 2 turns or so.
