RE: Stiletto from Corvidae.net
You don't need a split pushrod, do you? All you have to do is cut a slot in the side of the fuse, so you can insert the complete elevator assembly (with its "horn"). Solder a "ball link" ball on the elevator horn.... that way you can just push on the plastic piece of the link, which is connected to your pushrod, onto that ball...
