RE: Identify This Weedie Conversion Please
Thanks for the info about this engine....
I've advanced, and then retarded the timing from the ideal settings, and then set the timing to achieve peak RPM. Then I peaked the RPM by adjusting the "high" needle valve, and the performance I get is...... 5880 rpm from a 20X10 JXF propellor, and only 6460 rpm form an 18X10 Classic Master Airscrew!
That seems to be a disappointing.
What type of performance figures should I be getting?
Cheers,
Marcus.
