RCU Forums - View Single Post - Oxai E-Pinnacle Build
Old 04-15-2006 | 09:20 AM
Stuart Chale
Default RE: Oxai E-Pinnacle Build
The fuse is of interesting construction. The rear portion is a formed balsa skin with a layer of light fiberglass inside and out. The front portion is a heavy carbon fiber without a balsa filler. The chin cowl is also carbon fiber. The canopy and the fuse are partitioned off so that air entering the front scoop does not pass into the back of the fuse.
The rudder servo tray is installed and made out of a nomex fiberglass composite.
The rudder push-pull exit holes are in place, as is a tube for your receiver antenna.
The wing is held in by a single nylon bolt and wing nut and a single incidence adjuster pin in the rear. I will probably add n alignment pin to the front of the wing.
ID:	445657   Click image for larger version
ID:	445658   Click image for larger version
ID:	445659   Click image for larger version
ID:	445660   Click image for larger version
ID:	445661   Click image for larger version
ID:	445662   Click image for larger version
ID:	445663   Click image for larger version
ID:	445665   Click image for larger version
