RCU Forums - View Single Post - Oxai E-Pinnacle Build
Old 04-15-2006 | 09:41 PM
Stuart Chale
Default RE: Oxai E-Pinnacle Build
The canopy is attached with 2 screws in the front and the cowling with one at the front. There are two nylon alignment pins for the chin cowl and 4 I believe for the canopy. These have all been installed.
Here are the weights for all of the components. All of the small pieces were weighed with a 200 gm digital scale. The larger piece were weighed with a Pelouze 10 pound spring scale. Weights should be close but not as accurate as a digital scale. I do have a 5 pound digital scale that is lost in my basement somewhere. As soon as I find it I will provide additional weights.
Gear 123.7 gms, 4.365 oz
Wheel Pants 22.8 gm, .805 oz
Chin Cowl 43.2 gms, 1.53 oz
Canopy 157.5 gms, 5.56 oz
Wing tube 46.6 gms, 1.645 oz
Rt stab with carbon tubes 132.7 gms, 4.68 oz
Left stab 125.6 gms, 4.43 oz
The rest were weighed with a spring scale
Rt wing panel 15.75 oz
Lt wing panel 15.25 oz
Fuse with canopy and chin cowl 34.5 oz
Since the wings are now composite there are no seams to see. You can see the seams for the hardwood insert for the horns. There are also a few irregularities on the bottom of the wings. Really just a couple of small blemishes. Nothing too obvious. As far as I know, through Troy, the wings are the same airfoil and size as the IC powered version.
Stuart
