RCU Forums - View Single Post - u-can-do 60
Thread: u-can-do 60
Old 04-16-2006 | 12:30 AM
  #1492
Barry Cazier
My Feedback: (17)
Default RE: u-can-do 60
I would suspect if you put the fuel tank all the way back to the CG that you would have fuel pull issues without a pump. You could safely go back 2-3 inches from stock with out a draw problem.
No the 125 isn't too much engine. But it can be if you use too much throttle. Keep is slow and it will be safe.
I use a 16x6 APC or 17x4W APC with my Saito. Either would work very good on your UCD I would think.
I would stay with the inverted mount on the UCD. The engine runs fine inverted and installation will be much easier. Sometimes you can get a bit of flooding but it's not too bad. I run the engine inverted in all my UCDs.
Barry
