RE: Elevator Fluttering
I agree with MikeEast. In addition, large diameter/low pitch props keep the top speed down and make for better hovering/climb performance. You can also try to mass balance the elevator. Put lead ballast in the part of the elevator that is forward of the hinge line until the elevator's CG is on or slightly ahead of the hinge. This is done on most full scale airplanes.
