RCU Forums - View Single Post - Whys The Fuel going in there for instead of where it should?
Old 04-16-2006 | 10:11 AM
downunder's Avatar
downunder
Default RE: Whys The Fuel going in there for instead of where it should?
G'day Paul
Is the engine side mounted or inverted? This puts the muffler below the top level of the tank so you might be getting syphoning, especially if you use the pressure line as the vent when filling. If this is the case then the cure is to loop the pressure line up above the top level of the tank and make sure it's full of air after filling up.
