RCU Forums - View Single Post - Engine Mods??
Old 04-16-2006 | 02:18 PM
ryan_t888's Avatar
ryan_t888
Default RE: Engine Mods??
What I do for all my engines is tear drop the side ports and chamfer the boost port on the cylinder sleeve. Remember to Keep the swirling effect on the side ports. (away from exhaust) You may also open up the channels in the engine block as well. Once I did this I threw on a larger carb and got a bit more power and RPM's out of it.
I also do some work on the crank and rod.
Ryan
