wing help?
Sorry, I don't have a digital camera or scanner. I barely have a computer. The diagram pretty much sums up the problem, my trailing edge is just getting a bit on the small side.
The wing has no other problems and otherwise is coming together beautifully.
Should I just let it be?
The plane is a Sig Bonanza. I am already lightening the plane by making built up tail feathers in a V fashion rather than the standard config solid ones furnished with the kit. I am also not adding retracts (they are not in my budget) so I don't see that weight should be a problem. Well not until I build this plane the next time around.
