RE: Can I install Evolution Trainer Power System Engine in LT 40
You sure can. The Lt-40 is a great trainer and the Evo power system will be just fine on it
BTW, most any engine mount will work with the engine package. You do not need to purchase the mount they recommend. The fiberglass one that comes with the LT-40 works just fine. The only difference is you will have to drill the holes for the engine to mount to it instead of using the clamp on style they recommend
