RCU Forums - View Single Post - Engine Mods??
Old 04-16-2006 | 08:24 PM
ryan_t888's Avatar
ryan_t888
Default RE: Engine Mods??
I meant to only take material away from the path to the port on the sleeve. Not the actual port itself.
Balancing a single cylinder engine is extremely hard. Typically they are designed to resonate at a low RPM. If they resonated at a higher RPM there is more of a chance of them coming apart.
I just used a very small grinding stone, then I used high grit wet sand paper.
Ryan
