RE: Need help with Nitro Sport
lol go slow and save up, maybe dont gte a pullstart then, use the money for fuel and get more practice driving.
yes it does because it lowers the CG a lot.
also do this, put a limiter in the shock ( use fuel tube on the shaft ), of 8mm in the fron and 10mm in the back, then move the front shocks in to the closest to the inside and move the rear to the furthest out on the arm ( not the stock high position ). that will help a great deal if you dont make the shocktowers and get new shocks.
Dann
