RCU Forums - View Single Post - answer this ASAP
Old 04-16-2006 | 11:42 PM
nitrosteve22's Avatar
nitrosteve22
Default RE: answer this ASAP
Move the top of the shocks to the lowest setting in the shock tower,if you need more move the bottom of the shocks to the setting closest to the center of the buggy. If you need more than that you might have to bend back or cut off the little tabs on the chassis that are there to limit how low the suspension arms will go.
