had a bad day
i flew my showtime. On my UCD the frist flight i crasher because of the rec. But this one was successful. usuallyi an very nervious on the first 2 flights but i was fine this time .it is a solid flyer.right on th CG it only, only needed 1 pu and 3 left for the trim. flys real nice very smooth.
the engine only had 30 oz of fuel through it and idled fine than i took it up and it is still lean so it was not running like a broke-in engine does.
landed like a dream. on the 2nd flight my friend and i worked on KE mixing and no roll coulping just pitch
on the 3rd filght afthr i took off...the servo horn screw unscrew and the horn poped off it stalled at 75ft and spiraled to its death or what i though(when i knew i could not save it i turned my back)the frount of the fuse was damaged but i can fix it. nothing esle but 1 sfg was destroyed [:@][:@]
my dad said to rob his fuse and a sfg form his which is new in the box
he recored it so i will post a video in the next 3-5 weeks
thamks
38
