ORIGINAL: tuwood
Just out of curiousity; What servo problem did you have & what did you do to take care of it?
Tony, the issue would happen, not that it did happen.
I always isolate the servo plate with silicone that way any sharp vibrations would be removed. The only thing that gets the vibration from the engine is the fuselage and control surfaces.
I use J'Tec mounts too, but the Ultimate has a nylon mount, and that aluminum transfers everything to the fuselage so that's why I started thinking about isolating the electronics. Don't get me wrong, there will still be vibration, but not the hard vibrations like you would usually get. I still use the rubber grommets with the servos but the whole tray is isolated too. Tim
