RE: Skymaster MB-339
Hi Guys
I thought that the installation of the elevator servos,would be a piece of cake. Well,I was wrong,because one of the servo mounting blocks,which are inside the stab,was not in the same position,as what the other one was. The first one went quite quickly,but the second one,was another story. I had to grind quite a lot of the mounting away and also cut the aluminium brackets at an angle,to get the servo inside the allowed space. The problem was the location of the servo lead,which is attatched to the lower side of the servo casing. It was in the way of the plywood mounting. The other stab,did not have this problem and the lead cleared it. This is when I realised that the position of the mounts,were not exactly the same on both stabs.
Regards
Craig
S.A.
