RCU Forums - View Single Post - Pizazz Help
Thread: Pizazz Help
Old 12-14-2002 | 06:14 AM
Lazy Pilot
Default Pizazz Help
After an exhausting search for the "right" new plane, I bought a Pizazz a couple of days ago. From everything I'm reading here, and have read elsewhere, it seems I've made a good choice.
This is what I have: Pizazz, Futaba Super 8, Saito FA72, pull-pull rudder system, mostly Dubro hardware, carbon fiber rod for the elevator and I've ordered the TNT carbon fiber gear for the Sig Something-Extra to lighten the load.
The plane is almost done. I've yet to install the engine and have a couple control surfaces yet to hook up. All elctronics are in, including battery.
I'me using a 6 volt battery and I've placed it inside the wing as far back as it will go toward the trailing edge. I'm using all standard size servos and the stock fuel tank.
How am I looking so far on CG and general set up? Also, I'm aware from previous posts that the motor mount is weak and I'll be beefing it up as best as I can.
Any feedback or suggestions would be appreciated.
