RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 04-17-2006 | 11:52 PM
  #617
av8tor1977's Avatar
av8tor1977
Default RE: gas fuel with glo plug no ignition
That 13.5mm carb is a bit large for a Ryobi. Also, the larger carbs flow a bit more fuel stock, and may not need the regulator lever raised, especially when used on a smaller engine. My Poulan 42cc with a 13.5mm carb was blubbery rich after I raised the regulator lever. I put it back to stock and the engine straightened right out. I'm betting you are too rich, and the glow heat is covering it up.
You might also try a different glow plug in case yours is not "happy."
AV8TOR
