im in the process of cutting out some more holes in my body but i ran about 8 tanks without the body and with the ABS tires. the temp was just about where i think its suppsed to be (230-250) and only a couple times i heard it sound like it was over revving. so if i keep it like this should my engine stay pretty well intact? also, did you adjust the camber on your car to drift? cuz the 3 degrees on the back tires killed my ABS's they totally wore them down on the inside way more than the outside.
http://www.thatvideosite.com/view/1872.html . with my ABS tires theres no way i would be able to go that fast with that much control (or maybe i can but im just still learning). what tires could i get to be able to drift like that?
