RCU Forums - View Single Post - Looking for help... propeller sizing
Old 04-18-2006 | 07:27 AM
cmircman
My Feedback: (10)
Default RE: Looking for help... propeller sizing
I hope this plane is a multi engine aircraft. At 30 to 35 pounds i highly doubt this plane would fly with that engine(i could be wrong). If you need more static thrust go with a larger diameter prop with lower pitch. If you need higher speed go smaller diameter with higher pitch. Props that have more than 2 blades tend to produce less static thrust. Usually if you take a prop that the pitch is half of the diameter, will work more efficient and give you best overal performance than high or low pitch props. It all really depends on several factors like weight, drag, wingloading and much more. The only true way to find the right prop is to grab one and try it.
