RCU Forums - View Single Post - Looking for help... propeller sizing
Old 04-18-2006 | 09:52 AM
Ken Erickson's Avatar
Ken Erickson
Default RE: Looking for help... propeller sizing
jaff,
What you are trying to do throws the normal wisdom off a bit. The heavier you load the same airframe, the faster it must go to achieve the necessary lift. Therefore, you will need to experience a much longer takeoff run. Remember the drama of Lindberg's takeoff for the Paris flight.
There are formulas ( formulae) to calculate airspeed using the RPM and pitch.
You are not running out of elevator (unless the load is causing the plane to become nose-heavy), you need more airspeed before being able to lift off.
Think of the times you have been in a commercial airliner. The more empty seats, the shorter the takeoff run and vice versa.
Good luck,
Ken, AMA 19352
