RCU Forums - View Single Post - Training Wings for G3PO
Thread
04-18-2006 | 12:33 PM
1
mnowell129
Aug 2004
469
longwood, FL
This might help for pilots having some difficulties adapting
to rotary wing flight. A set of training wings.
I made these quick. If you make a set make real struts to the bottom of
the fuse because this mounting does tend to twist on the fuse.
The wing is set level with the top fuse member. The tail is set
horizontal with the tail boom.
23" x 4" 6mm depron.
3mm depron tail.
This does a couple things:
1) Improves the visibility.
2) Makes it very stable in pitch. (too stable for me actually but probably
this is a good thing). It doesn't change trim with power because of this. I'm not sure you have enough elevator to loop in this configuration.
3) Makes it much more spirally stable. Now it will hold a left or right turn
continuously only with elevator, once the turn is established. It tends to
fly straighter for longer periods of time as well, giving time to think.
Disadvantages if you are already flying G3PO:
1) The elevator gets very non powerful. It takes full up sometimes to
make tight turns.
2) Wind gusts make it bounce around because it has a wing. It corrects for
it but it does visible bounce around a lot more with the wing.
Summary:
If you fly helicopters already leave the wings off. If you have never
flown any kind of rotorcraft, these might be useful training aides until
you learn to use the left stick.
If there are enough requests I'll get them laser cut and make a little kit of parts if you want to retrofit.
mick
Reply
Like
mnowell129
View Public Profile
Send a private message to mnowell129
Find More Posts by mnowell129
View iTrader Profile
