RCU Forums - View Single Post - 2 meter plans
Thread: 2 meter plans
Old 02-19-2003 | 12:11 AM
  #87
bokuda's Avatar
bokuda
My Feedback: (7)
Default t2k progress report
Today I got one wing panel nearly ready to sheet. I just have to complete the shear webs around the wing tube and build the servo box.
I started on the wings because I ran into a problem with the fuse. I was trying to use the home-brew Piedmont mount for the Webra 1.45 I'm going to install.
http://piedmontmodels.com/dave_brown..._made_soft.htm
I found that the overall length of the set-up is 1/2" shorter than the plans show. I'm reluctant to shorten the cowl and moment that much. So I need to decide what to do; either build an engine mount box or use standoffs of some type. Or spring for a Hyde mount. I've asked for help with this on NSRCA mail list and have several suggestions. Among them is advice not to use the Piedmont homemade mount. Some people have said it works fine, though.
No problems with framing the wing. It's a little tedious trying to get everything perfect, but it will pay off in the end. Especially time consuming was getting the wing tube holes just right so the tube would not bind when installed. Any binding meant the tube was distorted and would not accept the inner tube. It takes a little patience.
Attached is a photo taken just before starting the wing showing the jig set up. I'm building on a luan door in my living room! My workshop is in the cellar, but it's cold down there. Living alone has its advantages.
I'll also post a photo of the wing as I left it for today. If I can figure out how to post two photos I'll attach it here. If not I'll repost.
Dave
