RCU Forums - View Single Post - Lazer 3D mini
Old 04-18-2006 | 07:32 PM
Blocker
Default RE: Lazer 3D mini
The instructions are pretty poor. It is written in 4 different languages and the translation is not the best. The cg is 65mm from the leading edge for fun fly or 75mm for expert. Ailerons throws are 15-20mm fun or 30mm expert. Rudder is 25-30 fun or 50mm expert. Elevator is 10-15 fun or 20 expert. These are the numbers taken from the manual. As far as radio installation, just install the servos in the supplied mounts that are built into the plane. You will have to determine reciever and speed controller so the model balances were you want it to. They are installed above the wing in the fuselage.
Hope this info helps. This is a very easy flyer, and alot of fun. Good luck
