RE: AV GAS and DA 50cc
AV gas is higher octane, which will have an equivalent effect to retarding the spark timing. This can cause overheating in extreme cases.
I would guess (but this is not factory authorized advice) that advancing the timing a couple degrees ought to get it back to where it belongs and should run great. But check with DA is good advice.
TF
