Fuel problem
I experimented with a 6oz bubbless bladder tank set up on the centre of gravity in my Taipan on Monday and had the strangest result that I'd appreciate comment on. I've made a bladder tank out of a square Kavan tank of similar dimensions to a Tetra tank, about 2" square by 4" long. The TT46PRO engine would needle perfectly on the ground, launch well and do the first lap running normally, then after one lap it would slow to about half revs.
There are no kinks or leaks in the suction or pressure lines. The muffler pressure nipple is clear.
I thought that if the tank was too far back for the muffler pressure available that the engine would die on takeoff when it experienced the first strong acceleration effects - not after one lap.
I'm keen to get this to work if there is a solution because the tank is right on the c of g so there is no balance change as the fuel is burnt off.
Any comments would be appreciated.
