RE: FALCON III COMPLETION
Looks like it should work but I agree that you should NOT tie the wiring to the frame. If you need to swap servos, BIG trouble. Cut it loose. Take a piece of thread/string and tie the connectors together so they cannot accidently come apart. You also want to be able to pull on them to route replacement wiring if needed. Also not much fun to cover the wing with the servos installed.
