RE: Help!! Servo problems
so whats 10KG work out to in in/lbs...? i m to lazy to google a eschange calc right now, get a HiTech HS645MG and put that on your steering. 40 bux at my lhs. or 60 for the digital counterpart HS5645MG... if you want to up grade both and have your stock steeign servo for a shelfer. then look to the HiTech HS625MG or the digital counterpart the HiTech HS5625MG... i just put a HS645 into my BB Maxx and although its a decent servo and it should work well in most conditions, but it is nowhere strong enough to give me the rusults im used to with my JR Z9000T servo i have in my aluminum TMaxx for steering. and with the big block im toasting servo horns like a dog, and a metal horn is the next step, but im sure it will kill the HS without to much trouble considerign the power the HB 26 gives me.... looks like one lhs gets another 300.00 of my hard earned.. 100 for the JR Z9000T and 200 for the OS 18TM im looking to get.. heh if your froggy and want good servo for steering i suggest the JR line in digital ball bearing servos, just use a 5cell hump pack instead of the 4 aa pack, UNLESS you have 4 2200 or more MaH AA rechargers. i have 12 Duracell 2500 AA MaH rchg batts, and they Rock Solid batts. but the hump will be best as you get a good 6v instead of 4.8.
Timmahh
