RCU Forums - View Single Post - Best nitro drift tires?
Old 04-20-2006 | 04:18 AM
Bigrustyman182
Default RE: Best nitro drift tires?
ORIGINAL: ratpoop
i have tried yokomo tires, and abs. i like the yokomo zero one tires the best for my nirto. they have more control then abs and the old double ring yok tires. but the abs will last longer. the only time i over heat is when i dont stop
i mean like i dont stop for like 20 minutes straight. my motor has seen temps in the 350 range. but i 'd say its adverage temp is like 280ish.
i have also tried the drift radials. they are fun for drifting fast. like 40mph drifts.
you must have 0 degrees camber cuz with my 3 degree (i think its 3, i just know its factory settings) it almost destroyed my ABS's the first time i ran them (about 6-8 tanks). im assuming its cuz of the camber cuz they are now way slanted haha. the best part is i can just buy a long tube of ABS pipe and cut tires myself. i think im going to try the electrical tape method on the middle to see if it gives me more control.
thanks for the help guys
