RE: help with servo problems
Might want to check that the metal gears are all properly connected to the shaft, so that one gear shaft isn't just spinning without the gear actually turning with it. I don't know the details of metal geared servos, but this is what I'd look at. Sort of like if a motor spun its shaft, but the pinion gear was loose..
