RE: Too much compression?
It will not be too much compression but more the cylinder nip that occures on ABC/ABN engines. This means that the engine will be on the tight side untill run in and looked after will last a very long time. I had an OS 46FX the same and lasted 15 years before brain fade took over and put it in the dirt.
Cheers.
