RE: "Fun-X" 1/2A pattern plane
Hi,
The Fun-X is a scaled down model of the Don Lowe Phoenix series. It would be simple to cut a foam wing from the plans or to get in touch with JM Glascraft as I am sure they can sell you a set of wing/stab cores The plane is built just like any fiberglass/foam plane, just in a bit smaller size. The firewall can be removed w/a Dremel if you wish and you can make a new one to any size you see fit. Personally, I would put a Tee Dee .09 R/C on one of these and have a small missle... If you decide not to build it, let me know... I can always use another pattern ship... LOL...
Dan
Carolina Custom Aircraft
