RCU Forums - View Single Post - Throttle linkage help
Old 04-20-2006 | 10:01 PM
Tym1_Me0
Default Throttle linkage help
Hi Everyone.
I need some help setting up the throttle linkage to a Homelite 30cc. I have a twister manifold so I'm able to run a straight pushrod to the carb throttle shaft. The problem is I can't get a completely linear throttle curve. I can set it up so that full throttle is at 1/2 stick or I can set it up so that idle is just less than 1/2 stick and full throttle is full stick. I just can't seem to get it so that full stick travel = full throttle travel. I'm using the middle hole on the servo arm. Any tricks or tips?
