RCU Forums - View Single Post - Help with cycling
Old 04-20-2006 | 11:13 PM
The Rook
Default Help with cycling
Hi there,
I have a question about discharging and/or cycling batteries. I have a multiplex LN-5014 and I would like to discharge and cycle a NiMH 3 cell 3.6 volt 150 mAh battery. What settings should I use?
I've only had experience charging Lipos, so I know virtually nothing about charging NiMH with a computerized charger like the multiplex. Can't you crank up the mAh for the charge without harming the battery? Does this reduce overall performance? Is it better to charge them with a very low mAh (is this what they refer to as a trickle charge?)?
Thank you for answering all of my ignorant questions!
J
