RE: 1/16 Leopard in MUD
After cleaning as much debris as possible from the tracks and inner upper hull, you remove the upper hull first, carefully as any remaining debris could fall into the motors, disconnect the four motor wires, then remove the front idler wheels and then tracks, remove the rear drive sprockets and the screws holding the gearbox and with a little effort the gearbox will come right out.
calvinwill
