Low end needle
Sounds like you may have turned the low speed needle in a little too far. Try backing it out a turn and see what it does. You want to adjust it for a reliable idle and a good transition from low rpm to high rpm.
there should be instructions for adjusting it in your paperwork.
Good luck
Tim
