RE: Bore
Yes you can do the sleeve just dont do the crank case. But you have to take the sleeve out of the crank case to do it do as i said with the marker but dont over do it because you can mess it up reall quick. And make sure you have a steady hand because one slip and the sleeve is now a paper weight so be careful.
