RCU Forums - View Single Post - Bore
Thread: Bore
Old 04-21-2006 | 10:20 PM
monsterpede360's Avatar
monsterpede360
Default RE: Bore
What do you mean by champher? could i bore out the intake hole were the airfliter sits on?
ORIGINAL: dannthenitroman
i think it wont be eligable for the lifetime replacement if you port it, but yes you can put a champher on the lower edge of all the intake ports and if you raise the exhaust port by about 1/2 of a millimetre you will gte more tp end. this will get you a lot more power all up but be warned, use common sense and NEVER get the dremel near the chrome ONLY the brass, the chrome will flake off and leave u with a dead engine.
Dann
