RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 04-22-2006 | 08:17 AM
  #624
captinjohn
Default RE: gas fuel with glo plug no ignition
AV8TOR: In general...would you say that a engine with more compression (higher ratio) is it going to run better or sames as a engine with a lower compression ratio. I am talking for gas/glow use. what have you found in your experiments as to C. ratio. Would a good name for your fuel be...GLOW-A-LEAN? Thanks Capt,n
