RCU Forums - View Single Post - 7CAP 5chan RX Flaps?
Old 04-22-2006 | 04:17 PM
Barry_DVRC's Avatar
Barry_DVRC
Default RE: 7CAP 5chan RX Flaps?
Move the aileron stick to the right. I'm going to assume that they both go downwards.
Viewed from the rear of the plane - with a right turn - only the left wing aileron should go downwards, right aileron should go up.
So reverse the channel that the right wing aileron servo is attached to. It will be either Chan 1 or 6 depending how you attached them to the receiver.
Hope this helps.
BTW to have the flaps both go up and down together on a knob you will need to use the FL-TRIM function.
Activate the FL-TRIM and set the % figures to the amount of movement you would require.
Best of luck
Barry
