RE: U-Can-Do 3d 46?
Hey all, well I only have been getting a half a flt. ea. of the last two days:-(... Got two today,
even with the rich S-82, I got a really nice holding F.S also this "Do" holds a K.E. a bit better
than the last one, it still pulls, but seems to be less or I'm just use to it now???.....
But I have been getting glitches everynow and then:-(.... She range check at 100' engine on/off
and I already switched rec's with no change... Today I pulled the ant. wire from the bottom of
the fuse and taped it to the wing, thinking that maybe my "Diamond shape" tailwires may be
causing the problem???
Anyway no glitches... But it took me a while to go back up to try it and the wind came up...
Anyway since my wires are as far apart as possible, and leaving the ant on the wing is a no
go... I'm thinking of how to route the ant. so as it'll end at about the tail servos.... Or the one
I'm going to try for the morning... Wrapping the ant. wire on a stick of bulsa with no overlap
just after the wing.. Anyone try this??? I heard pro's and cons on this method??? But I guess it
"can" work???? I know the 5 channel hitec rec I got for the SPAD came with a Ant. wire
bobbin so that the ant. wire could be wrapped on it to shorten it....
Well guess I'll find out in the am if the wind is down....
