RCU Forums - View Single Post - The TRUTH about using a real TX with a sim
Old 04-23-2006 | 08:50 AM
Maudib's Avatar
Maudib
My Feedback: (51)
Default RE: The TRUTH about using a real TX with a sim
It is NOT a good idea to operate your radio for long periods with the antenna down. This causes the transmission electronics to become overworked and heated. It is best to remove the crystal so that the transmitter is actually disabled. On the Futaba 9C I simply pop the RF module from the back of the radio.
People don't remove them to save juice (an added benefit), but to prevent damage to the crystal/electronics.
Sure it'll work fine, but you are heating those components up... somewhere down the orad, pehpas wiht a plane in the air, you might experience shortened range or worse, total failure.
ORIGINAL: Chriscru
Thanks for the replies guys all seems to work fine leaving the antenna in and collapsed..
Thanks for the quick replies...
Chris
