RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 04-23-2006 | 09:14 AM
  #4469
rclement's Avatar
rclement
Default RE: U-Can-Do 3d 46?
ORIGINAL: raideron
Rob... The dot is what I have for now... I forgot to order a fueler, I do have one but
I'm starting to work on the showtime and it's for it... It was a bit of a hassle having to
close the needle valve this morning to fuel, I thought I could just have the throttle close
and it would be like the YS(same setup) does with no problem... But not so......
Hey Ron, I'm going to take out my Dubro fuelers and replace them with fuel dots. I want something easier to use and that won't leak or fail. Anyway, the only time I've had glitching problems was on a Twist that I had. The Twists have a tube inside the fuse that runs right past both the tail servos. Couldn't get it to stop it from glitching. I even replaced the servos but it still glitched. It wasn't untill I took the ant. wire out and ran it along the bottom of the fuse that the glitching went away. On my U C Do I have it running along the bottom of the fuse and attatched to the tail wheel metal. It seems to work just fine. One way you could do it Ron is to run it along the bottom of the fuse in a zig zag or wavy pattern and keep away from the servos and tail area in general.
