RE: Max Carb Size On Stock Ryobi?
I would recomend that you check your exhaust duration timing, I have found some ryobi to have a very short duration timing on the exhaust at about 130 degrees I had to increase it to 145 degrees in order to get the desired performance I know for a fact that I am getting 8200-8300 rpms on an APC18x6W, so once again check the exhaust duration timing.
