RCU Forums - View Single Post - Foam suspension setup
Old 04-25-2006 | 02:03 PM
CEN Racing's Avatar
Default RE: Foam suspension setup
ORIGINAL: Midnitesky
I was starting to think there was no love out there.... Thanks alot CEN
What do you think about the 30's rubbing in the rear for a lap... or should I just stick with the 26's
Rubbing is usally not a good thing. If you could, you should make it so your tires don't rub. If this means going back to the 26mm then that is what you will have to do.
