RCU Forums - View Single Post - Clutch Slice- Quick Question
Old 04-25-2006 | 07:15 PM
ehroof
Default RE: Clutch Slice- Quick Question
hook the spring together, put around clutches, then put clutches on flywheel, its kinda hard to get the spring around the shaft of the engine if you leave the clutches in not to mention you can mess the spring up by stretching it out.
