ORIGINAL: jackkpl
ORIGINAL: Agent Midget
wow you might as well have no Exhaust.
sweet job, just sand her back a bit and it will look mint.
hope you dont mind if i make one useing your idea
Unfortunately 2 stroke engines dont suck fuel, they use exhaust pressure to push fuel into a carb. If u have no exhaust then engine would die at higher rpm (not enough fuel)
NOT TRUE AT ALL!!!! i read in the new mag that if you take the presure line off it makes the power band actuly more perdictable. it makes the low end more powerfull because the presure line pumps way to much fuel for the rpms even tuned right you take that line off and retune the motor and it will have a stronger low end and RCs do draw there own fuel its not the presure line.
