RCU Forums - View Single Post - Twist as second plane?
Old 04-25-2006 | 10:10 PM
Crash-D
Default RE: Twist as second plane?
If your looking for a good 2nd aerobatic beginner plane for cheap I'd highly recommend an Uproar either 40 or 60 and definetly go with the kit. I had an Uproar 40 as a 2 plane and it was great. There are some mods you need to do but otherwise it's extrwmly cheap, great flyer and will definetly train you for later.
The mods are; enlarging the rudder up and over the vertical stab about an inch, kinda like the way a giles rudder is. Nose heavy-ness can be an issue as these planes were made moe for 40 FP and i had a Supertigre 51 ringed that made my nose WAY heavy so consider making a battery hatch in the back and installing a servo back there. I elso heard form someone else somewhere here on rcu about increasing all the contol surfaces chords and up rates but you definetly dont need to worry about that. This plane is pretty comparable to a Twist as a guy at our field has on but with out the mods it lacks full potential, mainly with out that rudder.
Good Luck Darion
P.S. heres the forum with the uproar mods. http://www.rcuniverse.com/forum/m_40...tm.htm#4111510
