RE: TF Spitfire Build (Gold Kit)
Tubig,
Thanks for the pointer, i will do it. I do have a question, what do you use to make the steam? How do you apply it? Any pointers here would be great..
Attached are pictures of the wing joined together. I've installed the retracts and spent a lot of time adjusting the wheel well so the wheel would be hidden. You can see in the pictures that i reinforced the rib that i needed to trim. This made it easier to work. In the end the rib may need to be completely trimmed as i've seen in TUBIGs model.
